Forums › The Car › 206 Problems › Low RPM & Cut out |
Posted: Tue May 06, 2014 5:59 pm |
Hey all I drive a 2002, 1.1 Multiplexed
Today I drove my car to the shops no problem at all but when I came out it wouldn't start sounded almost like as if the immobiliser was Still active (I know it clearly isn't that but it was that noise).
I tried again but still nothing I disconnected and reconnected the battery and it ticked over but only to 500RPM I revved it and it sprung into life.
It lasted about 2 minutes right up until I got to the junction then same problem.
Managed to get it going again and seems ok however when idle my revs are only 800RPM (Normally 1000)
Does anyone have any ideas what this could be?
Cheers
Posted: Wed May 07, 2014 1:04 am |
Will it run with throttle applied? Is the problem just at idle and not when driving?
Posted: Wed May 07, 2014 1:54 am |
Yes it will but it did cut out when slowing down to a stop at a junction
Posted: Wed May 07, 2014 7:03 am |
I'm guessing you had the clutch on the floor and no throttle applied when it cut out.
Posted: Wed May 07, 2014 9:03 am |
I had shifted into nuteral and was rolling with no throttle applied
Posted: Wed May 07, 2014 10:04 am |
Posted: Wed May 07, 2014 10:35 am |
Cheers for that I'll have a shot at the weekend
