Latest: Worthy967
Overall: 17143
Online Now [420]:
Visitors: 419
Today: 109844
Total: 115754043
Forums › The Car › 206 Problems › 2002 peugeot 206 1.1 style rear axle issue.
Williamcorsa
PostPosted: Thu May 08, 2014 12:02 pm Up
Hi guys first post here. First of all i'd like to say this is my first car other than a vauxhall. I bought this car in February and have so far replaced the front drop links, drivers side wishbone, drivers side driveshaft, brake discs and pads and driver side hub assembly. I'm having an issue with the car now where it sits low on the rear. I can just about get my fingers in to check the tread on the tyre. There is no clunking or knocking at the rear nor is there any side to side play however i noticed there is play when you push the wheel up and down as if its driving over a speed bump, the shock etc moves with it but i'm pretty sure thats normal. Another thing i noticed was the when the car is parked on a hill etc the car doesn't really lift its back end up like it should. My friends 206 does this when it sits on a hill. I'm wondering if this is maybe the shock absorbers rather than the rear axle? There isn't any leaks i can see coming from them. any help would be much appreciated.
Cheers
Williamcorsa
PostPosted: Sat May 10, 2014 3:49 am Up
Anyone?
PostPosted: Sat May 10, 2014 5:04 am Up
Post a picture, Is the car lowered?
