Latest: Worthy967
Overall: 17143
Online Now [533]:
Visitors: 533
Today: 18541
Total: 115503708
Forums › The Car › 206 Problems › New Clutch, Sleeve & Cable Replaced... PROBLEMS
GlennMRX
PostPosted: Wed May 07, 2014 5:34 am Up
Hello,
I replaced the Clutch in my XS recently, Luk Clutch fitted, Genuine Clutch Cable fitted and replaced the sleeve/seal aswell, but the biting point is so high up the pedal, its about 10mm from the end of the pedal.
I have adjusted the pedal, it is now higher than the brake pedal, i cant lower the clutch pedal anymore or the clutch will slip?
Anyone any advice on how to put this right?? I am scared the clutch will soon start to slip and I dont want to ruin my new clutch
Glenn.
DREWDEN
PostPosted: Wed May 07, 2014 6:21 am Up
GlennMRX wrote:
Hello,
Glenn.
This thread will assist you.
Deckchair 5 comments.
www.206info.co.uk/Foru...48253.html
206 2ltr Hdi glx 53 plate
GlennMRX
PostPosted: Wed May 07, 2014 6:42 am Up
DREWDEN wrote:
GlennMRX wrote:
Hello,
Glenn.
thanks for that DREWDEN, I must go check if i can pull the cable out of the clutch lever at the gearbox, I must say when fitting the cable it was seriously tight to the point where we had to use a prybar to move the clutch lever back to get the cable in place! I even followed a Peugeot bulletin on how to fit the cable!
PostPosted: Thu May 08, 2014 5:40 pm Up
Sounds like the cable has auto adjusted before fully fitting.
PostPosted: Fri May 09, 2014 6:47 am Up
Or the cable is not correctky located on the pedal - it is fun getting that end on isn't it!
GlennMRX
PostPosted: Fri May 09, 2014 8:09 am Up
yeah my hand was cut to bits! Its located on the pedal ok... argh, gonna have to fork out for another cable! why couldnt they make it with a piece of threaded bar on the end and a wee adjuster nut? Had to try and be smart and make it awkward!
PostPosted: Fri May 09, 2014 12:26 pm Up
Because the auto adjusting cable has worked perfectly fine for many years on plenty of other PSA products.
It does the job perfectly, fit it correctly first time & then forget about it.
