Forums › The Car › 206 Problems › Error Code |
Posted: Fri May 16, 2014 7:27 am |
2 litre 206 has code p0410 secondary air injection system any one know what that means and how to cure it
Posted: Fri May 16, 2014 7:42 am |
Google search wrote: |
P0410 Peugeot Secondary Air Injection System Malfunction
Possible causes
- Faulty Vacuum hoses damaged
- Faulty Air Pump inoperative
- Air bypass solenoid harness is open or shorted
- Air bypass solenoid circuit poor electrical connection
- Air bypass solenoid leaking/blocked or stuck open/closed
- Air diverter valve leaking/blocked or stuck open/closed
What about the obd code?
The secondary air injection system does not detect the presence of air in the exhaust when introduced by the secondary air injection system.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Engine hesitation
P0410 Peugeot Description
An air pump is used on the vehicle to lower tail pipe emissions on start-up. The Powertrain Control Module (PCM) grounds the Air pump relay control circuit which energizes the Air pump. The PCM also grounds the Air combination valve vacuum control solenoid circuit, which energizes the Air vacuum control solenoid. Vacuum is then applied to both Air combination valve diaphragms which opens the shut off valves. The PCM enables both circuits simultaneously when Air system operations id desired. When the AIR system is active, then Air pump forces fresh air into the exhaust stream in order to accelerate catalyst operation. The AIR combination valves replace the conventional check valves. When the AIR system is inactive the shut off valves prevent air flow in either direction |
Posted: Fri May 16, 2014 8:56 am |
Thank you!!
