Posted: Sun May 18, 2014 3:26 pm |
As I was checking my screen wash, coolant, and oil I managed to snap the dip stick in half on the plastic bit that measures the amount of oil you have. So I took it out and cleaned it. Put it back in and on taking out to see how much was on it I heard a snap and when taking it out I noticed the measurement section was significantly smaller. Its due its MOT and service so will they be able to replace it or not? Also can it fail it is it doesnt have a full Dip Stick?
Cheers
Luke
Posted: Sun May 18, 2014 3:51 pm |
you can buy a new one from dealer,these are cheap.
Posted: Sun May 18, 2014 3:52 pm |
Thing is I cant retrieve the other half of the dip stick
Posted: Sun May 18, 2014 4:10 pm |
mmm..I understand,you might have to take the metal housing out,and then take it off.
Posted: Sun May 18, 2014 4:28 pm |
Dipstick tube off and retrieve (harder)
Sump off and pull out (easier but more work)
Posted: Mon May 19, 2014 2:13 am |
Timon2210 wrote: |
you can buy a new one from dealer,these are cheap. |
I got one a couple of years back. From what I remember it was less than £10
I think most of the ones on ebay are around the same price.
There are loads of 206 lumps running around with the plastic tip in the sump. It should be caught in the filtration system before it can do any damage.
Posted: Mon May 19, 2014 5:35 am |
I bought one from a scrap yard (It looked practically brand new), got it for free because I'd bought other stuff as well, try those first before you go to a dealer!
Posted: Mon May 19, 2014 10:39 am |
Dealers ones are roughly £10.04 for the common one (117475) but if you go to a scrapyard you may pick up the wrong one as they're different part numbers depending on the engines, but what the differences between them are I cannot be sure of.
