Latest: Mr-Koekwaus
Overall: 17125
Online Now [303]:
Visitors: 302
Today: 37162
Total: 99422326
Forums › The Car › 206 Problems › Second and Fourth gear not seating right
FrankAteMyName
PostPosted: Thu Nov 19, 2015 6:12 am Up
I drive a 1.4 8v Urban, 56 reg. It's covered 64,000 miles.
My gear knob has always had a lot of play in it since I bought the car. I did a bit of digging and it would appear that this could be down to the gear linkages. I have no issue with having a go at this myself - it's just time that's the issue.
Yesterday on the drive home I noticed that something felt off with my downshift to second. The gear knob did't go as far back as it usually does and it felt quite... Spongey? Like, if you pull reasonably hard to get it to seat where it used to it's as if someone has put some high density foam in the way.
After further investigation I realised that fourth gear was suffering similar issues. I ulled over, stuck it in reverse - no issues - and then second and fourth gear felt a little better. That is, until I started driving when they reverted back to how they were before.
Does anyone have any clue what could be causing this? It doesn't cause me much harm but it does occasionally pop out of second.
Cheers in advance,
Frank
PostPosted: Sun Nov 22, 2015 9:32 am Up
Check the Gearbox linkage,as it's the main issue,,also you need to check the cables the pulls the linkage.
PostPosted: Mon Nov 23, 2015 4:57 am Up
It could be the linkage ball below the gearstick as well, check that too
FrankAteMyName
PostPosted: Mon Nov 30, 2015 3:12 am Up
Thanks guys I should get a chance to have a go this week. I'll post results back here.
My cars:
206 Urban 1.4 8v 3dr '56 - China Blue - 70k Miles - Climate control retrofit, cruise control retrofit - Dead (Breaking)
206 GLX 1.4 8v 3dr '03 - 100k Miles - Obsidian Black - Black masked headlights + front fogs, Faster sunroof, Colour matched exterior trim - SOLD
206 2.0 GTI 138 '03 - 58k Miles - Onyx Black - 17" 180 Alloys - Current
206 2.0 GTi 138 '03 - 120k Miles - China Blue - New Track Toy (ON THE WAY)
