Latest: williamekstrom
Overall: 17124
Online Now [187]:
Visitors: 186
Today: 23705
Total: 99315548
Forums › The Car › 206 Problems › 206 SW Rear Axle & Suspension
RoaringMeg
PostPosted: Fri May 23, 2014 10:49 am Up
Hello
I have a 2003 2.0Hdi SW with rear brake drums and ABS. At the moment the noises from the rear are horrendous basically because everything is shot. The bushes in both torsion bars have worn excessively and I suspect the bearing in the radius arm on the offside rear has gone because the wheel is toeing in at the top and catches on the inner arch when going over bumps.
I have been offered a good second hand rear axle but it does not have ABS fitted. I understand that the backing plates and drums are different but my question is this. Is the axle set up the same for both non ABS and ABS and would it be a simple case of swapping my existing backing plates and drums onto the axle or can this not be done?
Thanks in advance Very Happy
PostPosted: Fri May 23, 2014 12:33 pm Up
I imagine you'd be able to transfer everything across.
