Online Now [906]:
Visitors: 904
Members: 1
Today: 171589
Total: 150475746
Forums › The Car › 206 Problems › 04 206 hdi 1.4
04 206 hdi 1.4
206hdihung
PostPosted: Mon May 26, 2014 3:30 am Up
Hi I bought this car about a year ago and it was fine until about two months ago then it has just fallen apart. First the torsion bar then some axel problems then a replacement maf. Now the turbo doesn't seem to be working and another warning fault light has come up. My local garage rub their has with glee when they see me pull up I can see the pound signs in their eyes!
Rant over! Potentially this is a very economical car whilst it leaks, the radio and courtesy light dont work I can live with this.
Apart from keeping my local garages profit margins high has anyone got any thoughts? I managed to changed the fuel filter last week but thats about as far I go, I can't even see the turbo.
kirk46
PostPosted: Mon May 26, 2014 4:39 am Up
you cant even see the turbo?
its staring right at you at the front of the engine bay
PostPosted: Mon May 26, 2014 4:47 am Up
Its a 10 year old French designed car with a crap engine design that was thrown together poorly by British worker's at Ryton.
Things will / do wear out & require replacement, this means either spending money on it OR getting rid & making it someone else's problem.
bodieanddoyle
PostPosted: Mon May 26, 2014 5:38 am Up
I'm sorry to say but if you are struggling then a local garage is going to be the only way. If you are dissatisfied with your regular garage then perhaps take some recommendations for another? Turbo problems from "its seized" to a split boost pipe (can you hear any whooshing sounds?) Or even a blocked exhaust.
They are great for saving running costs when they work well, I won't part with my 1.4hdi anytime soon.
drives a little green deep fat fryer. 1.4 hdi sw.
Antknee
PostPosted: Mon May 26, 2014 4:06 pm Up
If there's a fault being flagged then the engine power will probably be limited, also known as limp mode. Get the codes read and see what it has to say for itself. Might not be a problem with the turbo at all but something completely unrelated
cosmicdance
PostPosted: Mon Jun 02, 2014 11:35 am Up
Contrary to Mr BSI's angry rant these are good engines.
I have the 1.4 HDI Peugeot 206 on an 02 and have had very few problems with the engine other than a new crankshaft sensor which was causing stuttering.
Try disconnecting the MAF sensor and driving the car.
If it feels like there is still no turbo power with it disconnected then it could have died.
The MAF is one of the components that makes the turbo kick in.
It would be better to get the fault code read though as this is just a atrial and error procedure otherwise and potentially expensive.
I actually have a spare MAF from a 1.4 HDi as well so no need to spend £100 on a new from Peugeot.
A reputable technician who understands the HDi engine fully will track down the problem.
These forums do have some very helpful and knowledgeable people but then at the other end of the spectrum you just get guessed replies or people with PMT who want to let off steam.
Andy
Andy
cosmicdance
PostPosted: Mon Jun 02, 2014 11:44 am Up
Yes I would recommend getting the fault codes read by a reputable and knowledgeable technician who is familiar with these HDi engines.
You could also try disconnecting the MAF sensor and if it is still without turbo assistance it could be faulty.
Andy
Andy
