Latest: Andyblue64
Overall: 17123
Online Now [110]:
Visitors: 109
Today: 18432
Total: 99243259
Forums › The Car › 206 Problems › Which ABS Ring?
Which ABS Ring?
206Tom
PostPosted: Mon Jun 02, 2014 1:12 pm Up
Hi guys,
Need a new ABS ring for the 'shaft on the 206 - both 85mm and 90mm rings are listed though.
Is there a way to tell without measuring?
Its a 2002 2.0 HDi90 btw...
Want to order one tonight if someone can confirm.
Cheers
Tom
PostPosted: Mon Jun 02, 2014 1:23 pm Up
How much are they? You could order both.
206Tom
PostPosted: Mon Jun 02, 2014 1:33 pm Up
Well the 90mm is only £1.70 so not much, but the 85mm is a fiver!
Might have to order both as a last resort if there's no sure way of telling though.
206Tom
PostPosted: Thu Jun 05, 2014 12:07 pm Up
Well I gambled on a 90mm.
So of course I got it stripped down today to find its an 85mm on the car. :s
206Tom
PostPosted: Thu Jun 05, 2014 1:00 pm Up
Also (wont bother making another thread), not sure if I'm missing something, but when trying to put it back together I couldn't bend the wishbone down far enough to bet the BJ lower than the hole in the hub. I've not had this issue on other cars, I know it takes a bit of force but seems impossible on the 206....am I just weak or is there a knack to it lol?
PostPosted: Thu Jun 05, 2014 1:17 pm Up
Trolley jack under the disc could help. Not too much pressure though as it's dangerous
206Tom
PostPosted: Thu Jun 05, 2014 4:57 pm Up
Dangerous? Its currently only on one wheel, 2 axle stands and a jack on a sloping gravel drive... I like to live dangerously lol.
Will get the rears sorted first so I can drop them back down before doing any more at the front I think.
