Posted: Fri Jun 13, 2014 4:00 pm |
should my car still run with out a alternator belt belt on if the battery still has charge in it. its a 2.0 gti
Posted: Fri Jun 13, 2014 4:38 pm |
It will run BUT not for very long.
Also remember you will loose the power assisted steering as the belt also drives the PAS pump.
Posted: Fri Jun 13, 2014 4:59 pm |
Think mine has taken the csm belt out when it snapped then because mine won't start
Posted: Sat Jun 14, 2014 2:01 pm |
The belt might damaged the crank position sensor when it snapped.
Posted: Sat Jun 14, 2014 3:37 pm |
It won't because the crank sensor looks at the flywheel on the opposite side of the engine.
Posted: Sun Jun 15, 2014 2:35 pm |
Edward wrote: |
It won't because the crank sensor looks at the flywheel on the opposite side of the engine. |
Thanx for the correction,as I thought it's like my 1.4
Posted: Sun Jun 15, 2014 3:14 pm |
well I got my car home today only had a quick look and it doesn't look like its snapped my cam belt so my guess is that its jumped a few teeth
Posted: Sun Jun 15, 2014 4:51 pm |
What's the problem?
Posted: Mon Jun 16, 2014 2:42 pm |
my alternator belt snapped last week when I was on the way to work then my car just cut out and wouldn't start again
