Latest: Worthy967
Overall: 17143
Online Now [543]:
Visitors: 542
Today: 19759
Total: 115051115
Forums › The Car › 206 Problems › Mot fail Emissions
Mot fail Emissions
TattyWater
PostPosted: Thu Jun 19, 2014 2:25 am Up
My faith full little Pug has failed her Emissions test as follows.
Fast idle
CO : Limit 0.30% actual 0.50%
HC : Limit 200ppm actual 150 ppm - Pass
\ : Limit .970-1.030 actual 1.071
second Fast idle
CO : Limit 0.30% actual 0.58%
HC : Limit 200ppm actual 201 ppm
\ : Limit .970-1.030 actual 1.051
Any advise where to start to sort this out ?
Was thinking new cat and clean Lambda sensor ?
She is an old girl at T reg but only done 85K, and did have a loose joint to the back box.
Thank you
PostPosted: Thu Jun 19, 2014 3:28 am Up
When was the car last serviced?
Are you using supermarket fuel or something like Shell V Power?
A good hard run on a motorway can be enough to give it a clean out and reduce the emissions to a passable level.
TattyWater
PostPosted: Thu Jun 19, 2014 6:39 am Up
I was given the car in Oct last year, but no idea when last had service.
Buying some Bosch super4 plugs today and have used up the last of supermarket fuel with redex in it. Now filled up with Shell advance.
DeadEyePaul
PostPosted: Sun Jun 22, 2014 8:45 am Up
Pay for a service. Its cheaper than you'd think.
You'll probably need a new lambda sensor too as it looks like your fuel is running rich
bodieanddoyle
PostPosted: Sun Jun 22, 2014 11:28 am Up
Full service, ie plugs air filter and oil change. Check for air leaks. Probably a service and half decent thrash on a dual carriageway with sort it Smile
drives a little green deep fat fryer. 1.4 hdi sw.
TattyWater
PostPosted: Sun Jun 22, 2014 2:24 pm Up
Thanks Pepole.
I have put new exhaust on inc cat,super 4 plugs and V Power fuel = CO level worse.
Going to do oil flush and change, oil filter and Lambda sensor tomorrow.
The car is solid no rust anywhere and only failed MoT on this, but does have I think, a head gasket problem and needs new clutch.
TattyWater
PostPosted: Mon Jun 23, 2014 2:49 pm Up
Done Lambda sensor, oil and filter change - Still wont pass Mot.
Failing on Co still at 0.60 !!
PostPosted: Tue Jun 24, 2014 1:02 am Up
Have you changed the air filter?
TattyWater
PostPosted: Tue Jun 24, 2014 7:16 am Up
I took the air filter out for test !
PostPosted: Tue Jun 24, 2014 9:03 am Up
FFS Rolling Eyes
TattyWater
PostPosted: Tue Jun 24, 2014 1:22 pm Up
Tell me about it, put on new cat,lambda sensor,super 4 spark plugs,new oil and filter,dosed the tank of shell v power with redex, spent best part of £200 and the fecking CO reading is no better !!
kwakzx7r
PostPosted: Tue Jun 24, 2014 1:37 pm Up
No offense but does it not occur to you to try putting a new air filter back in and then re testing it Confused
TattyWater
PostPosted: Tue Jun 24, 2014 2:43 pm Up
Car is running too rich, hence no air filter = maximum amount of air going in to help weaken mixture.
PostPosted: Tue Jun 24, 2014 4:03 pm Up
More air means more fuel. Put the filter in.
Ali_H
PostPosted: Tue Jun 24, 2014 6:11 pm Up
This has to be a joke?
kurtis wrote:
