Forums › The Car › 206 Talk › Control arm (ball joint protector) |
Posted: Mon Jun 23, 2014 4:27 am |
Does anyone know if it is possible to purchase the control arm ball joint protector (rubber and 2 metal rings) on its own?.....if so.....where?
Thanks in advance.
Posted: Mon Jun 23, 2014 6:39 am |
Part number 3617 05, 3617 06 and 3615 09. £3.24 for both side of the car - Will some parts be minimum order quantity though?
Posted: Tue Jun 24, 2014 6:32 am |
Fish Brothers (Peugeot Parts Direct) sold me just the two, so maybe worth trying them. I've always found their prices to be good and postage is free
