Online Now [533]:
Visitors: 532
Today: 117749
Total: 153991417
Forums › The Car › 206 Problems › camshaft sensor b help
liam1988
PostPosted: Sat Jul 05, 2014 7:59 am Up
Hi guys I need to fix either the wiring or change the camshaft sensor b. is there other name for it as I can't find the parts on any sites?
Cheers
Smile
liam1988
PostPosted: Sat Jul 05, 2014 9:24 am Up
Apparently my car 1.6 16v 2006 model doesn't have them, buy I got the p1340 fault. Any help and advice appreciated.
Cheers
Smile
ukskater01
PostPosted: Sat Jul 05, 2014 12:07 pm Up
Is it starting/running ok? Could be the timing belt has slipped. You will have to check the timing first to rule it out if you have starting/running problems.
liam1988
PostPosted: Sat Jul 05, 2014 1:09 pm Up
It starts fine, I'm getting antipollution fault and when driving after a couple mins it feels like it's misfiring and slows down loads and shakes like hell. If I'm going up hill that is when it mainly kicks in and starts shaking.
Cheers
Liam
Smile
liam1988
PostPosted: Sun Jul 06, 2014 5:12 am Up
Just used my dhand held diagnostic kit on it again and looks at other into. It says 'oxygen sensor min' - inc. which means I'm guessing something wrong with the 02 sensor? If so, can I just unplug it to check and see if that's the problem?
Smile
