Latest: Flyin180
Overall: 17116
Online Now [25]:
Visitors: 24
Today: 486
Total: 95040685
Forums › The Car › 206 Talk › Fuel gauge
Fuel gauge
bigbert
PostPosted: Sun Jun 29, 2014 1:29 pm Up
Hi I'm new to the this site I've gone from a 106 to a 206 I've got the 1.6 Roland garros it runs fine but the fuel gauge doesn't work I've started at the pump and worked out its a problem with the actual gauge at the dash has anyone else had this problem and is there an easy fix or is it a new set of clocks thanks
ukskater01
PostPosted: Sun Jun 29, 2014 4:01 pm Up
Normally a new instrument cluster is needed but some tests need to be done to see if your getting a signal. The instrument clusters are pretty cheap second hand
bigbert
PostPosted: Sun Jun 29, 2014 4:31 pm Up
Ok I've tested the resistance from the float to the block connector at the clocks what other tests are there I'm a bit stuck on this one I've never come across problems with clocks before
