Online Now [849]:
Visitors: 848
Today: 104013
Total: 145787365
Forums › The Car › 206 Talk › peugeot 206 throttle problem
Forum Index › 206 Talk
fazuk
PostPosted: Thu Jun 26, 2014 4:40 am Up
Hi my mates Peugeot 206 1.6 16v wont rev up was working fine did not use for 2 weeks battery went flat jump started with jumpstarter pack and now wont rev also error p0123 thank for any help
PostPosted: Thu Jun 26, 2014 5:07 am Up
Reboot the BSI unit.
Using the jump pack has caused this fault code as the jump pack has spiked the electronic fly by wire throttle system.
fazuk
PostPosted: Thu Jun 26, 2014 6:59 am Up
Hi how do you reboot the bsi unit many thanks
David1156
PostPosted: Thu Jun 26, 2014 7:59 am Up
Here's the link:
www.206info.co.uk/Foru...c/t=20541/
Current: Albi Blue Clio 197
fazuk
PostPosted: Thu Jun 26, 2014 1:30 pm Up
I will try that many thanks
fazuk
PostPosted: Fri Jul 04, 2014 11:25 am Up
reset bsi started up rev fine turned off restarted but wont rev can anyone help thanks
PostPosted: Fri Jul 04, 2014 11:38 am Up
Connect to PP2000 and do an actuator test on the throttle.
