Latest: sparrowdclxvi
Overall: 17139
Online Now [103]:
Visitors: 102
Today: 5434
Total: 113533171
Forums › The Car › 206 Talk › Wire Identification for 2006 KFW 1.4 8v TU3A Engine?
very_452001
PostPosted: Sat Jul 05, 2014 5:15 am Up
This wire I found disconnected under the hood at the top of the engine bay (passenger side):
I cant seem to find the socket in the same area where the wire is to plug it in...
What does this wire do?
Car seems to drive normally with no lights on dashboard
very_452001
PostPosted: Sat Jul 05, 2014 5:34 am Up
Think it's for the alarm. Guessing you don't have an alarm fitted otherwise it would go to the siren module.
Lecktorious
PostPosted: Sat Jul 05, 2014 5:35 am Up
Trade Rating: +59
If you can't find where it plugs into, it probably does nothing anyway and if it did, you would have known before now.
If you look elsewhere in the engine bay you will probably find a few more unused plugs too.
'98 Nile Blue 306 GTi 6
very_452001
PostPosted: Sat Jul 05, 2014 7:00 am Up
Why would Peugeot leave unused wires in the engine bay?
Lets say something goes wrong with the car and the hood is open and the driver pops the hood and the driver sees a disconnected wire. So the suspicious goes straight on that wire.
Or a dishonest mechanic at a garage can use this wire against you and say all sorts of crap.
very_452001
PostPosted: Sat Jul 05, 2014 7:03 am Up
Cheaper to build one loom for different models and optional extras, than building an individual loom for each car.
Plenty of manufacturers do it.
PostPosted: Sat Jul 05, 2014 7:23 am Up
What He Said
Its the same in the forklift world to.
1 standard loom is just easier, saves on parts cost & space to.
PostPosted: Sat Jul 05, 2014 1:09 pm Up
I didn't know the 206 was sold in the USA.
Andrew
PostPosted: Sat Jul 05, 2014 4:32 pm Up
You'll find a few like this around the car. I also have the same engine code and even though it has manual wingmirrors, the connectors are there to attach electric ones
My 206 thread
www.detailedbyandrew.com
