Forums › The Car › 206 Problems › Seatbelt ight on.. Should I do this? |
Posted: Thu Jul 10, 2014 5:43 pm |
My seatbelt light is on but it goes out if I move my seat. I have been told by yo mechanics that I should go and see a local auto-electrician and get them to cut the connectors on both seats and the solder the together.
Is this a good idea?
Rick
Posted: Fri Jul 11, 2014 1:55 am |
If the connector is under the seat just fit a new connector.
Posted: Fri Jul 11, 2014 2:57 am |
Do it yourself? I reckon a dodgy connector under the seat. It would be a 5 minute job.
