Online Now [1050]:
Visitors: 1049
Today: 41379
Total: 151830924
Forums › The Car › 206 Problems › trying to get pp2000 to work
kirk46
PostPosted: Thu Jul 03, 2014 10:17 am Up
hi all just bought this and installed it all fine.
i get as far as to when it asks for the DAM i put the 4 digit number in from the door pillar, but it just goes back to the previous page where you have a choice for diagbox or pp2000, and if i choose pp2000 again it just reloads the same page
anyone have an idea what im doing wrong?
PostPosted: Fri Jul 04, 2014 6:08 am Up
Doubt it stall diagbox, just pp2000
PostPosted: Fri Jul 04, 2014 11:14 am Up
Diagbox can be a pain to get working.
Version 7.46 is the latest, if you go anything over version 7 then you need the interface flashing to revision C - using revision B on the interface will give problems.
[img]
[/img]
Technically you don't need even Diagbox for a 206, the older Peugeot Planet Office work's just fine.
The good thing about Diagbox is it work's on Windows 7 Cool
kirk46
PostPosted: Sat Jul 05, 2014 7:13 am Up
yeah its on a win 7 install atm.
its v7.44
PostPosted: Sat Jul 05, 2014 7:25 am Up
its v7.44
Is your interface revision B or C?
Unless it's C you will run in to issues.
kirk46
PostPosted: Sat Jul 05, 2014 10:54 am Up
ive no idea how do i find out?
kirk46
PostPosted: Sat Jul 05, 2014 11:04 am Up
found the interface checker but every think stays blank
PostPosted: Sat Jul 05, 2014 11:15 am Up
Click Activate, then version, then refrence - what does it say then?
kirk46
PostPosted: Sat Jul 05, 2014 1:31 pm Up
version stays greyed out :/
PostPosted: Sat Jul 05, 2014 2:02 pm Up
Something isn't installed correctly then Wink
You have installed the interface drivers & the green light is on when you try the interface checker?
kirk46
PostPosted: Sat Jul 05, 2014 2:12 pm Up
sorry didnt realise it had to be plugged in lol....
i have B Sad
PostPosted: Sat Jul 05, 2014 2:35 pm Up
i have B Sad
Laughing
Interface will need flashing to revision C to work with Diagbox after version 7.
Just install an earlier version of Diagbox OR Peugeot Planet Office instead.
206 doesn't really need Diagbox, Planet is good enough Wink
kirk46
PostPosted: Sat Jul 05, 2014 2:45 pm Up
but planet needs win XP?
how would i flash it to REV C?
kirk46
PostPosted: Wed Jul 09, 2014 8:39 am Up
anyone?
PostPosted: Wed Jul 09, 2014 11:17 am Up
Are you running win xp?
