Online Now [1631]:
Visitors: 1631
Today: 272604
Total: 152038380
Forums › The Car › 206 Problems › Loss of power
Loss of power
nick89
PostPosted: Wed Jul 09, 2014 6:57 pm Up
Hi all; So I've got a x reg 1.4 206, And my issue is that once the car has been running approx 5 mins, And i stop and dip the clutch, the rev limit starts jumping up and down, car starts juddering, sometimes a burning smell occurs and even if i rev her, more often or not she stalls, then wont start initially, usually on the 5th attempt, very annoying. Please help!!!
Recently given her a service and new coil pack, to no avail Sad
Cheers
Hawkers
PostPosted: Thu Jul 10, 2014 1:59 am Up
Lambda sensor (o2)? Clutch? You might need to get some diagnostics done.
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
PostPosted: Thu Jul 10, 2014 2:56 am Up
What kind of burning smell? Rubber, plastic, oil, clutch? Any signs of smoke?
What's your battery voltage like at rest and at idle?
What spark plugs did you use at the service?
PostPosted: Thu Jul 10, 2014 12:58 pm Up
Whistle...
What do we reckon the answer is going to be?
nick89
PostPosted: Fri Jul 11, 2014 4:17 am Up
Going to replace the lambda sensor, Hopefully it'll do the job; Occasionally their is also a smell of burnt oil, battery voltage seems to be normal, Used Bosch plugs.
I've no engine management lights, So would it be worth me forking out for diagnostics?
