Latest: DanDan17
Overall: 17128
Online Now [65]:
Visitors: 64
Today: 18771
Total: 100579449
Forums › The Car › 206 Problems › Seatbelt ight on.. Should I do this?
namrood
PostPosted: Thu Jul 10, 2014 5:43 pm Up
My seatbelt light is on but it goes out if I move my seat. I have been told by yo mechanics that I should go and see a local auto-electrician and get them to cut the connectors on both seats and the solder the together.
Is this a good idea?
Rick
newbie
PostPosted: Fri Jul 11, 2014 1:55 am Up
If the connector is under the seat just fit a new connector.
iainlovatt
PostPosted: Fri Jul 11, 2014 2:57 am Up
Do it yourself? I reckon a dodgy connector under the seat. It would be a 5 minute job.
(My Garage)
