Posted: Fri Jul 11, 2014 9:41 am |
It is not working on any speed and I have looked at the fuses which sound ok.
Any idea?
Posted: Fri Jul 11, 2014 10:17 am |
hamed206 wrote: |
Any idea? |
What kind of noise were they making?
Could be the resistor on the blower motor.
Posted: Fri Jul 11, 2014 10:28 am |
macca1411 wrote: |
hamed206 wrote: |
Any idea? |
Could be the resistor on the blower motor. |
They don't make any noise. The A/C is turning on, but the fan is not working at all.
Posted: Sat Jul 12, 2014 1:37 am |
the resistor need replacement,if it works,then it's fine,if not,a new blower motor needed
Posted: Sat Jul 12, 2014 2:04 am |
Resistors tend to stop one fan speed. A faulty resistor tends not to stop the fan completely.
Posted: Wed Jul 16, 2014 10:58 am |
Timon2210 wrote: |
the resistor need replacement,if it works,then it's fine,if not,a new blower motor needed |
Turned out to be the resistor. Replaced it with Peugeot OEM#6450.EP
Cheers
Posted: Fri Jul 18, 2014 11:03 pm |
hamed206 wrote: |
Timon2210 wrote: |
Cheers |
Glad that you got it fixed :),as with this hot weather in Egypt,you need the A/c for sure
