Forums › The Car › 206 Problems › Oil breather pipe split |
Posted: Fri Jul 18, 2014 3:38 am |
Trade Rating: +13
Can someone please get me the part number(s)? I can't seem to get into service box.
Posted: Fri Jul 18, 2014 10:39 am |
Does the pipe have ends that can be cut off the main pipe? If so then just re use the connectors and link them with some silicon hose.
Posted: Fri Jul 18, 2014 11:00 am |
Trade Rating: +13
Good idea thanks
