Latest: sparrowdclxvi
Overall: 17139
Online Now [273]:
Visitors: 272
Today: 9744
Total: 113131133
Forums › The Car › 206 Talk › Oil sump seal-replacement
Triggerfish
PostPosted: Thu Jul 17, 2014 12:18 pm Up
Right, I need to replace my oil sump seal.
Is it just a simple clean up of the contact parts of the sump and simply replace the seal with the new one and bolt back on?
Or are there anything special I need to do?
Thanks in advance.
206: 1.1L, 2002.
PostPosted: Thu Jul 17, 2014 12:34 pm Up
There is no seal to replace as such. You need a high temperature silicon sealant. Is it leaking?
PostPosted: Thu Jul 17, 2014 12:45 pm Up
Originally from the factory it was a sealant.
There are now sump gaskets available from aftermarket suppliers.
Triggerfish
PostPosted: Thu Jul 17, 2014 2:32 pm Up
Yes, it is leaking.....very slowly.
Well, under ECP, they sell one as "Elring Sump Gasket" (Part No.: 363545000)
There are now sump gaskets available from after market suppliers.
That's interesting.....and yes....now that would explain why I can't see it under Servicebox.
206: 1.1L, 2002.
PostPosted: Thu Jul 17, 2014 3:06 pm Up
Most of the time when people reseal them even with the correct sealant they normally don't cure the leak as they get something wrong:
Either distort the sump.
Too little or to much sealant
Don't let the sealant fully cure before putting the oil back in.
That's why there is an aftermarket gasket available, people are just in to much of a hurry to do the job correctly.
Triggerfish
PostPosted: Thu Jul 17, 2014 5:15 pm Up
...or maybe there isn't enough proper standard procedures for those who do wish to do such things.....DIY maybe.....or even the mechanic at some garages as there are more money to be made.....just get it done quickly.....?
So you guys think the after market gaskets are a good thing then?
206: 1.1L, 2002.
PostPosted: Thu Jul 17, 2014 5:48 pm Up
Sealing with sealant is the correct procedure, that's what I'd stick with.
PostPosted: Fri Jul 18, 2014 11:19 am Up
My local garage will insist on the car being left for 2 day's if someone wants a leaky sump resealing with sealant, they try & leave at least 24 hours for the sealant to cure before putting oil back in.
I had one done there many year's back, never leaked after they resealed it.
Triggerfish
PostPosted: Fri Jul 18, 2014 12:45 pm Up
Well, I can recall when I had mine done last time by a garage, I had my car back on the very same day.....couple of years ago now.
Takes discipline for a garage to insist procedures over money!.....not many I think...tbh.
206: 1.1L, 2002.
PostPosted: Fri Jul 18, 2014 5:34 pm Up
I left mine to cure for 24 hours. Never leaked since, touch wood.
