Online Now [53]:
Visitors: 52
Today: 26666
Total: 116678471
Forums › The Car › Solved 206 Problems › Ventilation air fan not working
hamed206
PostPosted: Fri Jul 11, 2014 9:41 am Up
It is not working on any speed and I have looked at the fuses which sound ok.
Any idea?
Hamed
PostPosted: Fri Jul 11, 2014 10:17 am Up
Any idea?
What kind of noise were they making?
Could be the resistor on the blower motor.
hamed206
PostPosted: Fri Jul 11, 2014 10:28 am Up
macca1411 wrote:
Any idea?
They don't make any noise. The A/C is turning on, but the fan is not working at all.
Hamed
PostPosted: Sat Jul 12, 2014 1:37 am Up
the resistor need replacement,if it works,then it's fine,if not,a new blower motor needed
PostPosted: Sat Jul 12, 2014 2:04 am Up
Resistors tend to stop one fan speed. A faulty resistor tends not to stop the fan completely.
hamed206
PostPosted: Wed Jul 16, 2014 10:58 am Up
Turned out to be the resistor. Replaced it with Peugeot OEM#6450.EP
Cheers Smile
Hamed
PostPosted: Fri Jul 18, 2014 11:03 pm Up
Cheers Smile
Glad that you got it fixed :),as with this hot weather in Egypt,you need the A/c for sure Very Happy
