Forums › The Car › 206 Problems › Fan Problem - Tired and Sick of it |
Posted: Tue Sep 09, 2014 2:01 pm |
Assuming these are good mechanics doing trustworthy work a failing water pump sound like the only thing left or blockage in the engine block. Do either of these faults occur on the Peugeots?
Posted: Thu Sep 18, 2014 7:15 pm |
Project2062014 wrote: |
Just put a cone filter on it . Or clean out the air inlet pipes as they get full of crap and the car runs hot( a new clean air filter aswell) .
Use the ac to cool evern more . Mine ran hot (petrol) found a half blocked air inlet as its in a poor place .put short pipe to filter under the bonnet & it never goes over 90 and if ac is on it sits at 80c or less when moving . |
I'll try with to change the Air filter... will see what will happen
thanks for your advice
Posted: Thu Sep 18, 2014 7:17 pm |
MrBSI wrote: |
What coolant mixture is in the engine?
Are you using readymixed coolant OR are you using concentrated at a 50 / 50 mix with water? |
It was readymixed Total Antifrize, then after washing the radiator I have a water inside... but it is same
Posted: Thu Sep 18, 2014 7:20 pm |
Actually, what are the Blue and Green sensors for?
I know when I'll disconnect the Blue sensor, the temp gauge is not working and the 2nd fan speed is on,
but never disconnected the Green sensor
Posted: Fri Sep 19, 2014 6:09 am |
Blue sensor is temp signal to temp gauge.
Green sensor is temp signal to ECU.
