Latest: lio94
Overall: 17181
Online Now [143]:
Visitors: 142
Today: 4775
Total: 141315566
Forums › The Car › 206 Problems › Wheel Hight Problem after jacking up rear : (
MattBurrows
PostPosted: Sat Jul 26, 2014 2:33 pm Up
Hi
I jacked up the rear left wheel so i could get to my exhaust silencer to fit a bracket.
when jacking up the car, the wheel stayed on the ground while the body lifted.
when i removed the jack the wheel stayed in its new position (so now the left rear of the car is in the air)
what could have caused this? can i fix it myself?
thanks
Walton450
PostPosted: Sat Jul 26, 2014 2:37 pm Up
have you let the hand brake off?
I\'m Steve got a 2003 verve.
DeadEyePaul
PostPosted: Sat Jul 26, 2014 4:17 pm Up
Mine does this and as soon as you drive off it drops back into position. I dont believe its anything to be concerned about
PostPosted: Sun Jul 27, 2014 3:23 am Up
OK, I've been away for too long and I don't get it..
Has this problem been resolved?!
MattBurrows
PostPosted: Sun Jul 27, 2014 6:33 am Up
yes i let the hand brake off (after lowering the jack)...
no the wheel has not gone back to its normal position after driving around
(the rear left of my car is higher than everything else)...
i cant find this issue in resolved issues section.
i need to know if there is anything i can do.
2.0 HDI TURBO SPORT: Thru Exhaust, Decat, Debadge, OZ Racing Alloys, Lexus Lights, P2 Bootstrip, Blue Dash/Footwell Lights...
PostPosted: Mon Jul 28, 2014 8:49 am Up
Maybe a tooth has slipped in the mating of the torsion bar (or even the rear ARB) when you jacked-it up and stressed it?
206gt160
PostPosted: Mon Jul 28, 2014 10:26 am Up
Highly unlikely the tooth has slipped in the torsion bar area unless it is seriously corroded. Could it possibly be that air has got into the damper some how, dodgy damper. Have you tried rocking the hell out of it to see if it settles??
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
Shadowstalke
PostPosted: Mon Jul 28, 2014 11:47 am Up
Pile some weight into the left rear passenger seat (maybe the boot as well for good measure) then either drive around a bit or rock it.
And just a real quick check (suprising what can be missed in a panic!) has the bracket/silencer interfered in any way with the ARB/Torsion Bar? Even just being in contact somehow?
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
MattBurrows
PostPosted: Thu Jul 31, 2014 5:34 am Up
yeah thanks...
it has sorted itself out a bit (but not 100%) after some intense rocking around.
I think i'm gonna chuck a couple of bags of cement in the left side of the boot and see what happens.
It's disconcerting, because if i did ever need to take the wheel off, i wouldn't be able too as no matter how high i jacked the car up, the wheel would still be on the floor
