Posted: Sat Jul 26, 2014 4:31 pm |
Erratic idling, hesitates on acceleration, not burning fuel, excessive gas consumption, exhaust smoke. ....all of these symptoms are permanently happening now significantly. I have no engine management light on. I had the coolant & MAP sensors changed plus the spark plugs during the last car service.
Something to mention, my spark plugs was fouled when I changed them last time.
Any help or advise?
Posted: Sat Jul 26, 2014 4:37 pm |
I would still get codes checked even if eml light is not on. A stored fault might point towards what problem is.
Posted: Sat Jul 26, 2014 7:22 pm |
I parked the car for 2 hours, now driving it no hesitation, no smokes, no smell of fuel, no more abnormal fuel consumption...it is just running smooth! I don't want this to happen again.
I had my car fueled to full tank today, does this has something to do with the problem? I lost 5-6 liters during few kilometers driving! And there were a smell of unburned fuel coming from the exhaust.
Posted: Sun Jul 27, 2014 3:52 am |
Sounds like a bad lambda sensor, you need to get Peugeot planet to see if any codes are there
| You never really learn to swear until you learn to drive | |
Posted: Sun Jul 27, 2014 7:27 am |
ukskater01 wrote: |
Sounds like a bad lambda sensor, you need to get Peugeot planet to see if any codes are there |
I'm suspecting the Lambda as it is an aftermarket one and done about 70K miles.
Posted: Sun Jul 27, 2014 6:55 pm |
Car is still idle erratically in the morning, and when hot...all the time! Sounds like a faulty O2 sensor.
Posted: Mon Jul 28, 2014 9:00 am |
Read the codes. Don't just guess and throw parts at it.
Do you have an exhaust leak?
Posted: Mon Jul 28, 2014 9:04 am |
Could be defective MAP or a few other reasons including Lambda but guessing and throwing parts at it gets expensive very quickly.
Posted: Mon Jul 28, 2014 11:17 am |
kandlbarrett wrote: |
Do you have an exhaust leak? |
I had an exhaust smoke (white smoke) when the symptoms were in the worst status. And a smell of unburned fuel. Not sure what do you mean by exhaust leak, if you mean a fault in the exhaust system like cracks, holes...etc, so no.
Posted: Mon Jul 28, 2014 11:18 am |
Could be defective MAP or a few other reasons including Lambda but guessing and throwing parts at it gets expensive very quickly. |
Not sure if the old 206 models will show the exact fault on a diagnosis test. Usually all faults appear under the name "Mixture Regulation Function"
