Latest: heikkisj
Overall: 17126
Online Now [65]:
Visitors: 64
Today: 10557
Total: 100246868
Forums › The Car › 206 Problems › 406 Brembo issue
406 Brembo issue
jonnyg2k5
PostPosted: Tue Jul 29, 2014 6:33 am Up
Just fitted a pair of 406 Brembo calipers to my GTI (138) and have used Xantia v6 Calipers 288mm. When I have come to refit the wheel (16" Nimrod) it will not fit as hits the caliper.
I presume I will need a spacer between hub and wheel? Anyone know whats the best size thickness to use for this setup?
Schumi
PostPosted: Tue Jul 29, 2014 7:41 am Up
Just put quantity of shims back of wheel for a measurement but never run your car with shims. Smile Smallest size it can clear is better. Only think I can said 16 mm is smallest spacer size you need for GTI180 alloy with 406 Brembo. You can walk over here.
2005 206 RC RED
jonnyg2k5
PostPosted: Tue Jul 29, 2014 7:56 am Up
Thanks Schumi.
The hubcentric spacers look good but there seem to be cheaper options (like £30 cheaper).....
For £8 quid on ebay you can get 10mm spacers they dont have a collar on to fit in the centre of the wheel - are these OK to use?
macj
PostPosted: Tue Jul 29, 2014 2:36 pm Up
only use hubcentric.... you will pay eventually if you dont
Targa180
PostPosted: Tue Jul 29, 2014 4:32 pm Up
sean.r.steward
PostPosted: Wed Jul 30, 2014 2:53 pm Up
y?
mtempsch
PostPosted: Wed Jul 30, 2014 11:25 pm Up
sean.r.steward wrote:
y?
Whole weight of the car is placed on the bolts instead of being carried by the hub/rim centre hole (and the bolts more or less just keeping the wheel on).
Silvermetallic 2004 206 RC
usher
PostPosted: Sun Aug 03, 2014 10:58 am Up
i sed 6mm spacers for a week then binned them as the wobble was unreal hubcentric all the way
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
JamieM
PostPosted: Mon Aug 04, 2014 2:36 am Up
I think I'll need some hubcentrics to fit my Brembo's the calipers look like they might touch my 16" Turinis... brrr
Aegean Blue 206 GTi180
usher
PostPosted: Mon Aug 04, 2014 1:41 pm Up
cant fit 406 brembos without spacers you can with the seat leon brembos using a custom bracket
project thread WIP
garage
FAQ
206 gti firedance
JamieM
PostPosted: Tue Aug 05, 2014 3:36 am Up
Ah I didn't know that, that's annoying. With my old Saxo they were a straight bolt on behind 15's for some reason I was under the impression for the 206 they were a direct bolt on without the need for spacers.
Cheers for the info!
usher
PostPosted: Wed Aug 06, 2014 12:13 am Up
team dynamic pro race fit without spacers even at 15"
project thread WIP
garage
FAQ
206 gti firedance
jonnyg2k5
PostPosted: Tue Aug 12, 2014 6:17 pm Up
Thanks for all the replies, I will get hubcentric ones. I'm kind of guessing at 20mm spacers even though I have measured with a rule anyone have any experience with the sizes required for 16" 206 Nimrods over 406 brembos?
