Online Now [914]:
Visitors: 912
Bots: 2
Today: 40789
Total: 151537497
Forums › The Car › 206 Talk › Anyone tried one of these auto fold mirror modules?
Forum Index › 206 Talk
PostPosted: Sat Aug 09, 2014 4:58 am Up
found this while browsing ebay, anyone tired one or similar??
www.ebay.co.uk/itm/gib...2c87756395
PostPosted: Sat Aug 09, 2014 7:11 am Up
Seems like a load of wires just to fold / unfold mirrors.
iainlovatt
PostPosted: Sat Aug 09, 2014 8:44 am Up
my only concern would be them folding in when the doors lock after driving off.
(My Garage)
PostPosted: Sat Aug 09, 2014 8:53 am Up
Wire it in to the deadlocking ( if you have it ) as that has safety logic built in Wink
PostPosted: Sat Aug 09, 2014 8:57 am Up
How difficult is it to move a switch next to the handbrake? Or if you have povvy spec like me, to move the mirror with your hand when you get out of the car.
PostPosted: Sat Aug 09, 2014 9:03 am Up
Works perfectly fine for me.
Normally after switching off ignition & opening door ( or waiting the 45 seconds for BSI to cut power to mirrors before I open a door ) I turn the mirror knob back towards the front so next time the ignition is switched on the mirrors unfold.
Technically speaking I could easily tack one of these mirror units on to the window total closure unit I have if I could be bothered Laughing
PostPosted: Sat Aug 09, 2014 12:17 pm Up
Normally I twist it before opening door and twist it back once door is open. Then when I start it up later they open when turn ignition on.
But im getting lazy Razz
PostPosted: Sat Aug 09, 2014 12:26 pm Up
Be nice if you could get hold of a wiring diagram for the device, then it will be easy to see how hard it will be to wire in to a multiplexed 206.
Hopefully its accepts a pulse input, if it needs a permanent ground input ( most devices like this do & most aftermarket alarms cater for them ) then it gets harder using the standard locking / alarm system to control it.
PostPosted: Sat Aug 09, 2014 12:59 pm Up
I found on some foreign site a bloke selling a module and it works fine on the 206. Chromes translater didnt seem to be able to translate all of it tho.
PostPosted: Sat Aug 09, 2014 1:04 pm Up
Google s**te Laughing
