Latest: williamekstrom
Overall: 17124
Online Now [79]:
Visitors: 78
Today: 10183
Total: 99342212
Forums › The Car › 206 Problems › Rev Counter not working
dimef
PostPosted: Thu Aug 21, 2014 6:26 pm Up
Hi guys,
any idea why my rev counter is not working on my 1.9D ?
What should I check? Is it because of the faulty panel or some engine sensor.
thanks
iainlovatt
PostPosted: Fri Aug 22, 2014 4:08 am Up
Buy a new one, easiest option make sure it the same plex as your car and has done less mileage than yours.
(My Garage)
southwestchap
PostPosted: Fri Aug 22, 2014 4:23 am Up
Sensor is down the back of the engine bolted about halfway down facing into the gearbox
As Iain says though, see if you can swap the cluster out to rule that out.
