Posted: Thu Aug 28, 2014 2:47 pm |
Hi
I have an issue with the rear axle on my Gti 138 from 2000
3 months ago i took the torsion bars out to adjust the hight, they were really stuck, so i ended up with the right hand trailing arm with the torsion bar in it on the floor hitting the one end of the torsion bar with a very big hammer. Finally Got it free, assambled everything again with new bearings.
Two months ago i had the car on a track, my brakes Where gone after so i put the car on axle stands and noticed that the 8mm bolt keeping the ARB in place where missing on the ledt side off the car, replaced with a new used locktite, making sure it wouldnt go again.
Saturday went to another trackday, after 40 minutes of driving on the cooldown trip i noticed a Cling sound from the ledt rear everytime i took a leftturn.
We jacked the car right rear, and the wheel stayed on the ground
I suspected the splines on the torsion bar or on the rear axle to be destroyed more or less.
I have the rear axle off the car now and the torsion bars are out, and i cant see any wear on the splines?
But when i try to refit the torsionbar its a tight fit on axle, i cant push it in with my hands, but on the trailing arm i can is this right?
Could it be the ARB? The left side arm is still stuck on the ARB?
| 206 GTi 2.0 2000 Trackday+ Daily
205 GTi 1.9 1987 Project
Citroen C4 Grand Picasso 2.0 VTR+ E6G 2008 Family car
Old cars
Mazda 3 1.6 16v Diesel 2008 - Peugeot 405 1.9 Diesel 1989 - Peugeot 309 1.4 Kick 1991 - Vw Polo 1.3 HIT 1986 - Mazda 626 1.8 1988 - Peugeot 205 GTI Project car - Ford Escort 1.6 16v 1996 - Peugeot 205 1.4 XR | |
Posted: Fri Aug 29, 2014 3:40 am |
Did you replace the bearing on both side?
As far as i remember, torsion bar is already tight fit. I normally use a small hammer to knock it in.
Posted: Fri Aug 29, 2014 7:15 am |
Seabook wrote: |
As far as i remember, torsion bar is already tight fit. I normally use a small hammer to knock it in. |
Yes both sides and with Genuie parts from Peugeot
If i recall it right it used to be a tight fit, i will try the other side and see if that is a tight fit
Old cars
Posted: Fri Aug 29, 2014 8:33 am |
Did you put copper grease on the torsion bar splines? You did rotate the bars to find the position that they will slip into both axle and trailing arms?
Posted: Fri Aug 29, 2014 10:00 am |
Edward wrote: |
Did you put copper grease on the torsion bar splines? You did rotate the bars to find the position that they will slip into both axle and trailing arms? |
I used some ceramic grease on the splines?
Yes turned the bar until it would slip in to both axle and trailing arm, i Think i Got it in 5-6mm and then i had to use some force to get it all the Way in.
Old cars
Posted: Fri Aug 29, 2014 10:07 am |
that sounds fine....
But i will be surprise if the splines can get damage.....
Posted: Fri Aug 29, 2014 12:24 pm |
Did you clean everything before assembly?
Posted: Fri Aug 29, 2014 12:39 pm |
Edward wrote: |
Did you clean everything before assembly? |
Yes i cleaned the torsion bars for 3-4mm of corrosion protection, ended up with two almost new looking bars in dark red with yellow ribbons.
And i used a small screwdriver to remove dirt and rust from the splines on both the bars and axle
Old cars
