Online Now [1165]:
Visitors: 1164
Today: 340106
Total: 151457039
Forums › The Car › 206 Problems › Unsolved Overheating Problem-Couples of Symptoms Together!
Go to page 1, 2, 3, 4  Next
hamed206
PostPosted: Sat Sep 20, 2014 3:45 pm Up
MY car which is very old (2000) started to have several issues together!
Car ONLY OVERHEATS on HIGHWAY with a speed EXCEEDS 70KM. It reaches 110 degree. It will overheat also under 70km ONLY WHEN the A/C is ON. ECU indicator flashes from time to time (once per day), when flashing, the car hesitates a little, sometimes cut-out but will start immediately from the first attempt. I don't know if this is related to my overheats issue.
Also in the last two times I change the spark plugs, there were excess carbon deposits on the sparks which indicates bad fuel/air mixture. My crank sensor is new. MY lambada is 70K miles old. My MAP sensor was replaced 5 yrs ago.
I have really changed lots of parts and can't solve the problem. I'm afraid that changing the radiater wouldn't fix the problem.
Parts replaced till now:
-Both temp sensors (brown and green).
-Thermostat.
-Fan resistant.
-The relays were tested ok.
-The water pump is new (was replaced 3 months ago).
-Head gasket is ok.
-Cylinder head was skimmed due to an overheat issue occurred before. It was only 0.25mm skimming.
-Crank sensor was replaced (it was faulty).
-Motor oil was replaced in the regular service.
-Air filter is new.
-New radiater reservoir cap.
Please any suggestions?
Best.
Hamed
Leegsi
PostPosted: Sat Sep 20, 2014 4:03 pm Up
If its running lean that will make the engine run hot I think
hamed206
PostPosted: Sat Sep 20, 2014 4:06 pm Up
Temperature goes above 100 with A/C and 90 without A/C.
Hamed
badj
PostPosted: Sat Sep 20, 2014 4:51 pm Up
Water Pump.
Pretty common culprit for those kinds of symptoms.
If the rad looks alright and you're confident the exhaust isn't blocked, then I'd be looking at water pump.
Iceland Blue '99 206 GTI (140) - SOLD
KMF '05 1.4 HDi
PostPosted: Sat Sep 20, 2014 4:57 pm Up
Air conditioning should make it run cooler because the fan is more likely to be on.
hamed206
PostPosted: Sat Sep 20, 2014 7:16 pm Up
badj wrote:
Water Pump.
It is new. And Peugeot OEM.
Hamed
hamed206
Right. So what is this???!
Hamed
badj
PostPosted: Sun Sep 21, 2014 1:42 am Up
hamed206 wrote:
badj wrote:
Water Pump.
As per the other points then, exhaust and rad?
KMF '05 1.4 HDi
PostPosted: Mon Sep 22, 2014 3:22 am Up
If your plugs are sooty then that is car running rich. A rich mixture will cause it to run cool. A lean mixture will cause it to run hot.
If your car is running rich and overheating ypou may have more than one single problem.
I would connect to a code reader, note the codes and then clear them. Take it for a good long drive and re-read the codes.
Throwing parts at it may cure it but may also get very expensive and achieve nothing.
Do you have an exhaust leak, air intake leak or leak on any of the breather pipes under the bonnet. What condition is the air filter in. Have you tried cleaning the MAP(T).
hamed206
PostPosted: Mon Sep 22, 2014 5:00 am Up
kandlbarrett, good points and good note about rich run cool, and lean run hot.
But why it run hot only with A/C on? This is a good symptom to follow that may lead to the solution.
It is very hard to get sufficient information with a DIAG test in old 206 models.
Does the fan relay (the green one) has something to do with such an issue? There are two green relays. I have changed the fan resistant, and the water thermostat during the last service. The green relay is the only thing I didn't change till now!
My mechanic is suggesting that because it overheats with A/C, so may be there are dirties between the radiator and the A/C coil.
I had an old MAP sensor, so I used it....but still the same.
I was suspecting the Lambda sensor to be the cause of the "rich" running as it is an aftermarket sensor.
Peugeot is full of troubles!
Hamed
Project2062014
PostPosted: Tue Sep 23, 2014 3:17 am Up
your problem actually sounds like a radiator problem.
It COULD be the thermostat, however if it only over heating with the A/C on, on a hot day, Then I believe your radiator needs flushed.
Over time the radiator will develop corrosion in the tubes and reduce the cooling capacity. The coolant has corrosion inhibitor in it when new , but, they degrade over time and lose the ability to prevent build up.
1) Check that the radiator and reservoir is full of coolant.
2) If the coolant is not a clear pink or yellow, it needs replaced.
3) if you do it your self , buy a flush kit from the auto parts store and install it in one of the heater hoses. follow the directions on the kit. to flush the engine, you will need to be near a water hose.
4) use the recommended mix of anti-freeze to water...usually 50/50.
5) buy and use some "Water Wetter" it will increase your cooling capacity and mitigate this type of overheating.
6) Check that the fan is working and your belt is in good shape.
7) look at the radiator through the grill, is it plugged with dirt and other road debris? use the high pressure washers at a car wash to clean out the fins, wash out the stuff that gets in there.
Cool check air inlet for half a forest .
PostPosted: Tue Sep 23, 2014 5:46 am Up
Lambada....love it.
gazza82
PostPosted: Tue Sep 23, 2014 9:18 am Up
Or sand or part of a camel in this case .. the car is in Egypt! Wink
So I'd guess the system may struggle anyway with the temps they get
andyh2003
PostPosted: Tue Sep 23, 2014 1:11 pm Up
im no mechanic, but could it be an airlock in the cooling system ?
hamed206
PostPosted: Wed Sep 24, 2014 6:22 pm Up
But we don't have a Camel in Egypt. May be the Mummy's Curse Laughing
Hamed
Page 1 of 4
