Online Now [1122]:
Visitors: 1121
Today: 154788
Total: 152551872
Forums › Tuning, Modification & Legal › Project Cars › new 206 gti 138 owner
andy83
PostPosted: Sat Sep 27, 2014 2:27 am Up
bulbs checked and in place and seem to be in good condition, next question is do the reverse lights have a fuse i could check?
andy83
PostPosted: Wed Oct 01, 2014 10:40 am Up
iv fount the reverse light problem to be the reverse light switch so ordered a new one and will be fitting it this weekend
on another front iv now ordered a maniflow 4-1 manifold and a pair of powerflex bushes for the engine mounts and started to get the bits required to convert to the 180 inlet manifold, iv purchased a 306 gti 6 throttle bodie and icv. just gotta get the inlet and 180 alternator now.
PostPosted: Wed Oct 01, 2014 1:15 pm Up
Pair of power flex mounts? You need three.
Project2062014
PostPosted: Wed Oct 01, 2014 2:13 pm Up
nice !
(De-cat) get the lambda extension. Get a flexi joint off the manifold !
andy83
PostPosted: Wed Oct 01, 2014 2:40 pm Up
Ill link you up to the parts I got from powerflex.
Cheers for the heads up matey should imagine it will make a nice little improvement
andy83
PostPosted: Wed Oct 01, 2014 11:04 pm Up
www.powerflexshop.com/...ad-use-206
Ref: 20 - Lower Rear Engine Mount Bush (1 Bush) - PFF50-306 +£29.88
it seems like the other one i ordered was for the 1.4 engine so it looks as if powerflex only do the one bush for the engine mount?
andy83
PostPosted: Wed Oct 01, 2014 11:18 pm Up
going off the diagram it looks as if its the rhs engine mount, so ill need the gearbox mount/bush still and superflex/powerflex dont do them so id imagine i need to get a vibratechnics one?
Project2062014
PostPosted: Thu Oct 02, 2014 1:08 pm Up
Strip out spare wheel frame jack etc rear seats+ plastics & remove old air inlet pipe and metal bracket & its quick as ! Much better on the road .Light weight front seats in my nxt mod .
I have not got mounts or bushes as of yet . Do need some soon . Il see how you get on then probably copy your order to get it right . Engine does move alot .. wish i could help more . 8-(
andy83
PostPosted: Fri Oct 03, 2014 7:58 am Up
thats ok fella iv fount you guys on here to be very helpful cracking forum Smile
iv now just purchased a 180 inlet manifold so only need the 180 alternator now and i should have all the bits required for the inlet conversion
andy83
PostPosted: Mon Oct 06, 2014 8:12 am Up
so i received the gti 6 throttle bodie/icv and powerflex lower engine mount bush, 180 inlet should be here tomorrow or weds.
Project2062014
PostPosted: Mon Oct 06, 2014 8:15 pm Up
What you doing with the egr pipe ? Also ivc goes ?
andy83
PostPosted: Mon Oct 06, 2014 11:19 pm Up
egr i believe gets blanked off, icv is required as the old one cant be used ill tell you where it goes when fitting Smile
andy83
PostPosted: Wed Oct 08, 2014 6:15 am Up
Bit of an update for you iv got the car booked in for sat morning at psi tuning in Newcastle under Lyme to see whats what before I start adding the exhaust and Inlet manifolds plus a remap.
Will be interesting to see what shes got still.
andy83
PostPosted: Thu Oct 09, 2014 8:43 am Up
another update for you all, iv decided to go for a supersprint exhaust manifold thats designed to fit the oe cat, so less hassle etc etc, we are limited for the amount of time the car can be off the road as the wife uses it for work each day.
iv also ordered a set of kw -40mm lowering springs this should still keep the ride height practical but give it a much better stance, and ordered the vibratechnics gearbox engine mount, im hoping to fit the manifold/mounts and lower it in 1 day then the wife can have it back to get to work.
Project2062014
PostPosted: Thu Oct 09, 2014 3:03 pm Up
wait . Fit exhaust manifold plus de-cat also fit the Inlet if you can .
4-1 manifold best for flow. one on Gumtree 50 quid a couple days ago .. then get it remapped for best results . Mrs aint gna be happy lol . Took me 4 hr exhaust manifold to cat fitted & welded.
Ive contacted 2/3 tuning comps and they will not help further after they are told of my first remap .
Ring psi .make sure they will run the car again & be able to remap it after your mods . If you go first like i did .after map i Fitted mods & no remap ! Wtf . Anyone out there in southwest ??
What price is your remap at psi remap ?
Page 3 of 9
