Latest: williamekstrom
Overall: 17124
Online Now [108]:
Visitors: 107
Today: 10796
Total: 99342825
Forums › The Car › 206 Problems › Driver's door lock
Driver's door lock
dan00dle
PostPosted: Sun Sep 21, 2014 1:38 pm Up
Hello all - first post. Hopefully someone can help?
I have a 2007 1.4 206 Look. Strange issue when coming back home today. The central locking would only lock the boot. Fiddled around trying both the fob and the button in the car next to the hazards switch. Managed to get it to lock the passenger door and the boot with central locking. This also happens with the auto locking when driving, leaving the driver's side unlocked.
I'm having to lock the driver's side manually Sad
Anyone else had this issue? Is it likely the motor for the driver's door lock has died?
Any help appreciated, thanks!
PostPosted: Sun Sep 21, 2014 1:41 pm Up
Door lock motor failure is common on the 206.
Be warned there are 2 different types & there NOT interchangeable.
Some 206 are normal central locking while others have deadlocking, make sure you get the correct replacement lock motor.
dan00dle
PostPosted: Sun Sep 21, 2014 1:50 pm Up
Thanks for the quick reply. How do I identify which locking type I have?
PostPosted: Sun Sep 21, 2014 1:59 pm Up
Does your 206 have deadlocks fitted?
Being a LOOK spec I doubt it.
