Posted: Sat Sep 27, 2014 9:59 am |
Changed bulbs but no joy where is the fuse? looked on the forum is it f23 in the engine box 10amp fuse? as i dont know if the cars pre-plex or multi-plex as stated on here and i cant find it listed for mult-plex. Cheers in advance
Posted: Sat Sep 27, 2014 11:08 am |
99% of the time it will be the switch, common problem & cheap from a Peugeot / Citroen main dealer.
Unplug the switch, short the connector plug terminals out on the loom connector & turn the ignition ON - if the reverse lights now work you know the switch if faulty.
2003 will be multiplexed.
Posted: Sat Sep 27, 2014 4:43 pm |
cheers for info
Posted: Sun Sep 28, 2014 2:14 am |
i also have the same problem checked the bulbs they were fine and fuse is ok, so id imagine its the switch as mrbsi has kindly pointed out
