Latest: Kifi69
Overall: 17183
Online Now [1285]:
Visitors: 1284
Today: 179864
Total: 144807859
Forums › The Car › 206 Talk › ESP fuse...
ESP fuse...
Forum Index › 206 Talk
PostPosted: Mon Sep 29, 2014 6:28 am Up
the link on here showing the engine fuse box etc for multiplex looks nothing like the engine fuse box i have??
im trying to locate the esp fuse?
esp faulty comes on as soon as engine is started (within 3secs of engine turned over)
PostPosted: Mon Sep 29, 2014 8:38 am Up
You should get the codes read before pulling fuses. The comm unit might have been replaced and not set up properly with PP2000
Fuse 6 (10 amp) in the passenger compartment is for the ESP steering angle sensor amongst other things
If the diagrams are to be believed, and no reason why they shouldn't be, the fuse is also the ABS fuse, so if your ABS is working, then should be no need to pull the fuse.
Don't have ESP on mine so can't help with the fusebox diagram. Maybe put a picture of yours up and someone might be able to help
