Hi there, over the last 2 days my 206 1.1 has started to run cooler, it usually sits happily around the 90 degrees Mark but now will hardly get above 80, tophose is red hot, any ideas what could be the problem? Don't want a head gasket problem.
Posted: Tue Sep 17, 2019 7:01 am
If its running cooler I would suspect the thermostat is stuck open so not allowing the engine to get up to the correct operating temperature.
TU1 thermostat is a simple job to replace, might as well fit a new coolant temp sensor at same time ( check what colour the sensor connector is before ordering! )
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
