Latest: williamekstrom
Overall: 17124
Online Now [167]:
Visitors: 166
Today: 25805
Total: 99317641
Forums › The Car › 206 Problems › Central Locking Not Working 2005
Fionny
PostPosted: Wed Oct 15, 2014 2:52 pm Up
Hi All,
New problem with my wife's 206 (2005) LX. Central locking has stopped working.
When the car is locked manually with the key and you press the buttons the lights flash outside as you would expect. Cabin light goes on and off also. When you sit in the car and do the same there is a click on the dash somewhere but nothing happens either.
I looked at the fuses under the steering wheel (#16 I read) it doesnt LOOK blown but is it worth changing it anyway?
Any other ideas?
Thanks,
Fionny
Fionny
PostPosted: Sun Oct 19, 2014 12:49 pm Up
So we changed the fuse, no change... any suggestions folks?
VorTechS
PostPosted: Mon Oct 20, 2014 10:16 am Up
Staff - Vortechs
Could be one of the solenoids is gone.
I think you can try disconnecting them one at a time, and once the car locks, you've identified the one that needs replacing.
I may have made that up though..... Very Happy
Also, if you've changed door cards recently, just check that there is enough clearance all round at the top of the card for the locking button. I had that as a problem once when I changed things around...!
