Latest: sparrowdclxvi
Overall: 17139
Online Now [148]:
Visitors: 147
Today: 33328
Total: 113365154
Forums › The Car › 206 Talk › Air box
Air box
Ciaran996
PostPosted: Sat Oct 18, 2014 10:40 am Up
Took the airbox connected to my air filter off today as i just wanted a little more induction noise and a big improvement but does anyone suggest what i should put on instead of the standard enclosed air box?
David1156
PostPosted: Sat Oct 18, 2014 10:51 am Up
You could buy a cold air induction kit although it's debatable whether or not they actually make any difference in terms of performance. They will however make a lot more noise. If you wanted to keep your standard airbox, you could just drill holes on the part of the box before the air filter to add more noise.
Current: Albi Blue Clio 197
PostPosted: Sat Oct 18, 2014 2:35 pm Up
Drill holes in the air box below the pannel filter and remove the air intake from the wheel arch. That makes more noise
Ciaran996
PostPosted: Sat Oct 18, 2014 3:48 pm Up
Very good idea thanks alot
sean.r.steward
PostPosted: Sun Oct 19, 2014 5:57 am Up
just remove the pipe and box going onto the bottom of the air box. when done avoid standing water on road
