Online Now [2652]:
Visitors: 2651
Today: 523799
Total: 153358767
Forums › The Car › 206 Talk › Solution for overheating of Peugeot 206 - simple and dirty.
Forum Index › 206 Talk
MUHAMED
PostPosted: Sun Oct 26, 2014 2:43 pm Up
Guys checkout this solution for overheating of Peugeot.
This is probable solution of FAN starting problem. Page is on portugese and use google translate to translate it:
vitrinecars.blogspot.c...mento.html
That is quick and dirty solution. You need thermal switch and adapter with only 3 wires. It will be much more reliable than factory setup with relays, ECU control and resistor.
and maybe fitting radiator like this one:
(This one is for 206 1.1 without A/C (like mine)).
www.direnza.co.uk/peug...iator.html
will improve engine cooling too.
This system can be added in parallel to existing one. In order to be sure that fan will kick on when needed.
I believe that it can be a just another useful mod.
