Latest: sparrowdclxvi
Overall: 17139
Online Now [229]:
Visitors: 228
Today: 22763
Total: 113094230
Forums › The Car › 206 Problems › Ecosse 5 stud conversion
Project2062014
PostPosted: Mon Oct 27, 2014 11:17 am Up
What is ecosse ?
How do they do a 5 stud conversion ?
like this .
Drill holes where needed. !
How the wheel bearing stayed on i dont know . Just fell apart .
Disk was held on by the spacer bolts .
If thats the standard of work at ecosse then i WOULD NEVER USE THEM A FIX A LIGHT BULB !
PostPosted: Mon Oct 27, 2014 11:24 am Up
Your not the first person on here to have been Ecossed
PostPosted: Mon Oct 27, 2014 11:49 am Up
Wow
Just wow
Project2062014
PostPosted: Mon Oct 27, 2014 12:44 pm Up
Threads have been drilled tapped at different angles .
Drilled by hand in a vice drunk ?
Project2062014
PostPosted: Mon Oct 27, 2014 1:04 pm Up
48mm spacer .
AWK-53
PostPosted: Mon Oct 27, 2014 2:50 pm Up
Blimey!
PostPosted: Mon Oct 27, 2014 3:36 pm Up
If that was mine I would be tempted to launch it through their window or stick it where the sun doesn't shine. That is worth reporting to trading standards or asking the ministry of transport to investigate.
Project2062014
PostPosted: Tue Oct 28, 2014 9:52 am Up
The otherside . Cannot get nut off .
Does this look right ?
PostPosted: Tue Oct 28, 2014 1:50 pm Up
It looks like something that came off the Titanic.
lip_88
PostPosted: Tue Oct 28, 2014 2:49 pm Up
This is shocking really
lip_88
PostPosted: Tue Oct 28, 2014 2:52 pm Up
