Posted: Thu Oct 30, 2014 8:20 am |
Posted: Fri Oct 31, 2014 7:05 am |
to me the grease nipples seem like a good idea just i would do it when the suspension is disassembled just to be safe. the motorcycle shocks at the end of the thread seem interesting though
| GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow | |
Posted: Fri Oct 31, 2014 9:03 am |
Grease nipples are excellent idea. I believe that mostly water that is coming inside bearings and due to corrosion the axles can be prematurely work out. So to install grease nipples you don't even need to disassemble rear arms.
It can be done easily. Twice a year just lubricate them. Simple and dirty solution.
Can you post a link of motorcycle shocks how to be installed ?
Seems interesting mod too.
Posted: Sat Nov 01, 2014 5:06 pm |
If you have ever seen a suspension arm apart you will know that the casting is hollow, to get the grease to reach the bearings you would probably need two litres of grease to fill the void before you had any hope of grease reaching the bearings.
Posted: Sun Nov 02, 2014 1:21 am |
I was just thinking the same. You'll just end up filling the whole trailing arm with grease. If you really are desperate to stop wear just put loads of grease on the bearings and strip the axle down every couple of years.
Posted: Sun Nov 02, 2014 1:10 pm |
lol That is called maintenance I am not so rich to buy new car every 5 years.
