Latest: Kifi69
Overall: 17183
Online Now [326]:
Visitors: 325
Today: 1104
Total: 144148204
Forums › The Car › 206 Problems › Mechanic Said rear axle don't have toe adjustment . WTF :(
emhtuning
PostPosted: Wed Nov 13, 2013 3:12 am Up
hello guys .
took the car for rod alignment , read tiers toe were little bit out . but mechanic said the 206 don't have toe adjustment at the back .
first I believed him , but then I said how come there is no adjustment .
so if there is no adjustment , How you guys repair the rear wheel wearing ?
thank you and sorry if the topic is covered already , but search couldn't find any info .
Lecktorious
PostPosted: Wed Nov 13, 2013 3:49 am Up
Trade Rating: +59
He's right, it's fixed. As is the camber.
Wear on the inside of the tyre could be a sign that the trailing arm bearings are failing.
'98 Nile Blue 306 GTi 6
emhtuning
PostPosted: Wed Nov 13, 2013 3:53 am Up
OK , thanks a lot for your confirmation ,
if possible can you guide me to which part is needed to be replaces ( maybe ebay ling or any online site ) just for reference .
I drive GTI 180 ( we call it 206 RC here in Dubai ) .
thanks again
PostPosted: Wed Nov 13, 2013 4:21 am Up
It's these bits you need. Those bearings wear but once you get movement in the arm there is a chance the axle pin will be damaged. One side on mine has some marks but has no play in the arm so just think what the axle would look like on one with wear showing.
I'd order a new axle if that's what your problem is.
emhtuning
PostPosted: Wed Nov 13, 2013 7:00 am Up
thanks Edward .
will have a look at it , i will pass by the dealer to see if i can get the bearings only or I must change the whole axle.
PostPosted: Wed Nov 13, 2013 2:39 pm Up
Main dealer for this work will be expensive! still living in Dubai you may be an oil baron with loads of money.
Lecktorious
PostPosted: Wed Nov 13, 2013 4:21 pm Up
Trade Rating: +59
Wouldn't be driving a 206 if he was though! Laughing
gazza82
PostPosted: Wed Nov 13, 2013 4:53 pm Up
How do you know? Might be gold plated Wink
emhtuning
PostPosted: Tue Jan 14, 2014 8:05 am Up
lool , how i missed this conversation Very Happy , yes I live in Dubai
the RC is one of my favorite cars , I drive it at least 3 times a week , it's really good for city drive .
PostPosted: Thu Jan 16, 2014 2:55 pm Up
And what was the final fix and cost of that for your car? The regulars here hate it when the poster just disappears without telling all.
MUHAMED
PostPosted: Fri Oct 31, 2014 1:17 pm Up
add grease nipples on the rear arms. It will increase lifespan of the roll bearings.
