Online Now [201]:
Visitors: 200
Today: 31883
Total: 142937994
Forums › The Car › 206 Problems › Help!!! Urgent Advice Needed
206Mark007
PostPosted: Sun Nov 02, 2014 11:32 am Up
Right need help urgently. Right ive got a 1.1 206 that after driving for 3-4 hours the cat glows red and forces the car to stop and run bad. Revs really bad. Any advice of what is wrong with the car?
New Parts brand new fitted
Coolent Temp Sensor
Map Sensor
lamba Sensor Both
Cat
Timing Belt
Water Pump
Aux Belt
Alternator
Power Steering Pump
Coil Pack Valeo
Bosch spark plugs
TPS Sensor
New Fan and housing from Peugeot
New Radiator
and
Scrapper throttle body
Second hand Ecu Added too
PostPosted: Sun Nov 02, 2014 11:35 am Up
Was it a cheap cat that you bought?
206Mark007
PostPosted: Sun Nov 02, 2014 11:38 am Up
Type R approved cat mate
qwert
PostPosted: Sun Nov 02, 2014 12:46 pm Up
Cats f****d
brum brum
Project2062014
PostPosted: Sun Nov 02, 2014 12:48 pm Up
Blocked cat low on flow of gas ?
206Mark007
PostPosted: Sun Nov 02, 2014 1:07 pm Up
Cats brand new and had the same problem with the old cat. Im thinking it could be injectors?
PostPosted: Sun Nov 02, 2014 2:13 pm Up
Over fueling more than likely, could be a number of reasons though. Engine light on?
PostPosted: Sun Nov 02, 2014 2:22 pm Up
I notice the OP mentions the throttle body & ecu have been changed, wonder if there the correct one's for the engine.
206Mark007
PostPosted: Sun Nov 02, 2014 2:27 pm Up
Engine light has been on and off as i reset it with code reader. p0170 fuel trim bank 1 p0300 random misfire p1336 misfiring some of those codes might have come on because we had car running with some sensors off when we changed everything all have been cleared now and will get another reading tomorrow light has come back on again tonight.
throttle body and ecu are defo for correct engine. They have been sourced via specailised companys and are like for like part numbers on the back.
PostPosted: Sun Nov 02, 2014 2:30 pm Up
Engine ecu software update from a Peugeot main dealer?
206Mark007
PostPosted: Sun Nov 02, 2014 2:32 pm Up
Not had it a main dealer. What update does it need?
PostPosted: Sun Nov 02, 2014 4:28 pm Up
Front lambda could be knackered, giving false reading so over fuelling.
PostPosted: Sun Nov 02, 2014 4:45 pm Up
Right so you have a misfire code yet you havent sorted it?!
The reason its getting red hot is because all the fuel that is bore washing the cylinder is getting thrown into the cat. Your new cat is f****d since you have fixed a simple misfire
Side note, check the resistance on the injectors should all be near on the same
