Posted: Mon Nov 03, 2014 2:00 pm |
I know this has been covered a few times, but couldn't find much with the search......Basically looking to retro fit electric mirrors to my dturbo 2002.
Checked under where the switch is for the windows and there is a spare connecter I would assume is for the mirrors.
However when i checked under the mirror cover on the inside, there is a brown connecter with about 5/6 wires...which connects to the mirror and this just has 2 wires assuming for my heated mirrors........Is it a case of buying the correct switch then finding some leccy mirrors with the brown plugs?
Posted: Tue Nov 04, 2014 6:18 am |
Want to upload a pic?
But generally yes that is all you should need to do!
Posted: Tue Nov 04, 2014 7:26 am |
Will get one up later of both plugs. After doing some reading appears there are 2 type of plugs white and black so just a case of figuring which I need
Posted: Sat Nov 08, 2014 6:15 am |
Bit of a delay but this is the plug/wiring in the drivers side
