Forums › The Car › 206 Problems › 206 Oli filter housing full of oil |
Posted: Sat Nov 15, 2014 12:12 pm |
Dear All, I have just changed the oil on my daughter's 206 1.4 petrol. I drained the sump before I removed the filter and was surprised to see the filter housing was still full of oil - I had to drain it with a syringe. Is this normal? The car runs fine and sounds good.
Many thanks.
Posted: Sat Nov 15, 2014 12:55 pm |
Quite normal yes.
Posted: Sat Nov 15, 2014 1:10 pm |
Funny enough, yes
| Team Impossible Possible
Posted: Sat Nov 15, 2014 3:52 pm |
Most grateful
