Latest: sparrowdclxvi
Overall: 17139
Online Now [176]:
Visitors: 175
Today: 37272
Total: 113108600
Forums › The Car › 206 Talk › Unibody Differences between hatchback and Cab??
AX-Rated
PostPosted: Tue Nov 18, 2014 1:41 pm Up
Hey all,
Its a weird query I know, and one that i've found hard to answer just by searching t'internet.
But what differences, if any, are there, between the regular 206 and 206cc unibodies??
Did they strengthen them or is the standard 206 unibody design strong enough without the roof?
Anyone got pictures of undersides of the two models for visual comparison?
Thanks.
Black 03 GTi
PostPosted: Tue Nov 18, 2014 1:42 pm Up
There are strengthening bars fitted under the CC, get one up on a ramp & you will easily spot them.
AX-Rated
PostPosted: Tue Nov 18, 2014 1:43 pm Up
Cheers for the quick reply.
Would love to see any photos of the undercarriage of one for comparison.
Black 03 GTi
AX-Rated
PostPosted: Tue Nov 18, 2014 1:44 pm Up
Is these what you're on about MrBSI?
Black 03 GTi
PostPosted: Tue Nov 18, 2014 1:45 pm Up
That's them.
gazza82
PostPosted: Wed Nov 19, 2014 5:10 am Up
Probably stronger sills as well ... those bolt on bars are unlikely to stop it flexing ...
They are rattling b*gg*ers when they start to age as well!
AX-Rated
PostPosted: Wed Nov 19, 2014 12:41 pm Up
I was thinking the the same. The way those bars are laid out, would stop torsion along the body rather than lateral stiffness around the mid section.
Black 03 GTi
PostPosted: Wed Nov 19, 2014 1:59 pm Up
Dunno about the 206 but the 207cc has a big sprung metal block behind the drivers side rear wheel to cancel out and flexing and vibrations running through the shell.
AX-Rated
PostPosted: Wed Nov 19, 2014 2:02 pm Up
Love to hear more about that Edward, got any more info/pictures?
Black 03 GTi
PostPosted: Sat Dec 13, 2014 2:59 pm Up
This is what I was talking about. Big sprung metal block that rotates slightly.
