Latest: ArtistKS
Overall: 17145
Online Now [46]:
Visitors: 45
Today: 15726
Total: 115915623
Forums › The Car › 206 Problems › Low Cooling Fan Relay
Carlos_WR1
PostPosted: Thu Nov 20, 2014 2:10 pm Up
Forgive me if this is a stupid question but could i use a 30amp relay as the replacement for the 25amp relay used for the low fan cooling?
would the 5 amp difference be safe.
Main reason is i can get a 30amp relay straight away but am having trouble finding a 25amp one locally.
I know i could go to the dealer but how much would they charge for a relay?
ukskater01
PostPosted: Thu Nov 20, 2014 2:59 pm Up
Phone a dealer, they can't be that much. You never know it might actually be cheaper than the motor factors!
PostPosted: Thu Nov 20, 2014 3:03 pm Up
Should be fine to use a 30amp relay. It's all fused anyway.
Carlos_WR1
PostPosted: Thu Nov 20, 2014 3:35 pm Up
Cheers mate ill get 1 tomorrow and fit over the weekend.
I got error code P0485 come up, i know the high Fan works but i dont think the low fan is so guessing itll be either the relay or resistor.
mtempsch
PostPosted: Thu Nov 20, 2014 4:53 pm Up
The current rating on the relay tells how much current the switching contacts can handle, so it's OK to use a higher rated relay. The opposite is not true.
Silvermetallic 2004 206 RC
RichardEke
PostPosted: Fri Nov 21, 2014 3:35 am Up
Morning,
I bought a relay from the dealer last year and it was £4 iirc. Ordered friday, arrived Saturday ready to pick up.
The low speed resistor was quite expensive though!
As Edward said, cause it's fused it'll be fine to use the 30amp relay.
Regsrds, Richard.
Life would be easier with universal jointed arms and fingers sometimes
Carlos_WR1
PostPosted: Fri Nov 21, 2014 7:25 am Up
Well im hoping it wont be the resistor, i managed to get a new one ordered and only paid £7.99 but it wont be with me until Weds so hoping its the relay.
