Online Now [543]:
Visitors: 542
Today: 233724
Total: 149621298
Forums › The Car › Request a how-to › replace window/mirror control
andy83
PostPosted: Fri Nov 28, 2014 12:20 pm Reply with quote Up
hi everyone just thought id ask you good people on how to replace the centre window/mirror controls?
ours decided to snap off in my hand last night Shocked
id imagine to existing one should just flick out and then replace with new unit ?
any tips appreciated
PostPosted: Fri Nov 28, 2014 1:05 pm Reply with quote Up
The knob does come of the mirror switch if your heavy handed, sometimes it can be re attached if the shaft is still intact.
If it's a complete switch unit swop then:
Unclip it from the centre console then unplug the 2 connector plugs from the switch ( press down on the locking clips before attempting to remove the plugs ) it's not exactly rocket science.
HOWEVER: Make sure you get the correct part number switch as a replacement, there are MANY switches that lock exactly alike from the outside BUT are different inside ( even just on the 206 range! )
At best it wont work correctly, at worse it will pop the window fuse Laughing
andy83
PostPosted: Fri Nov 28, 2014 1:28 pm Reply with quote Up
thanks alot for that i knew it wouldnt be rocket science just thought its best to double check.
oh iv done it properly lol
macj
PostPosted: Sun Nov 30, 2014 7:41 am Reply with quote Up
which switch do you have Andy. I have a second hand mirror switch in a GT with mirror park
  Quick Reply
Username:
Message:
Quote the last message
