Online Now [1078]:
Visitors: 1077
Today: 251787
Total: 150549560
Forums › The Car › 206 Talk › Gti 180 lowering for performance not looks
Forum Index › 206 Talk
Yan180gti
PostPosted: Fri Aug 29, 2014 5:08 pm Up
Will putting lowering springs on my car make it bumpy ?
Project2062014
PostPosted: Fri Aug 29, 2014 8:23 pm Up
Springs will be fine . Coilovers ! The lower you go the harder ride !
PostPosted: Sat Aug 30, 2014 1:12 am Up
No need for coil overs on a road car. £ for £ you will get a higher quality spring and damper than coilover.
Project2062014
PostPosted: Sat Aug 30, 2014 1:38 am Up
who makes a good set of dampers and springs? tried and tested ? .
PostPosted: Sat Aug 30, 2014 12:51 pm Up
Bilstein make good dampers although my first lot were dangerously corroded after 7 years. I still use Bilstein though and now have H&R springs. Previously I used Eibach.
PostPosted: Sat Aug 30, 2014 2:25 pm Up
i used to use koni yellow sport before and it was ok; with eibach pro sport spring.
intermilan206
PostPosted: Thu Nov 27, 2014 11:33 pm Up
I'm using koni yellow sport with koni-supplied springs (perhaps made by H&R).
Overall, handling department is much better than original Peugeot setup.
Ride quality is good, its slightly ply at low speed and get firmer as the speed build up.
Soft/hard (rebound settings) is adjustable to your liking.
Ride is only affected on the worst road surfaces.
206 1.6L 16V XT - RIP
206 GTi 138++
Koni Sport dampers, H&R springs, GTi180/RC rear axle and front ARB. Sparco strut bar, Yokohama AD08R tyres, Raceland 4-1 manifold, Remus backbox, Magnaflow sport cat, Catcams Fast Road cams, Unichip Q piggyback ECU, Pipercross VIS kit, Vibra Technics mount kit, 283mm Brembo Max front discs and rear discs, Ferodo DS2500 front & rear brake pads, Goodridge brake hoses, 307 23.8mm master cylinder, brake servo and calipers; Quaife LSD, AST adjustable top mounts and 206 WRC rear spoiler (just can't resist it).
Postpone / KIV / Coming soon: Mocal oil cooler kit.
Removed: Combrake top mounts.
